William C. Griffin
- Prince George, Va
I have several parking lots that we keep in good repair. One of them, is wired on 208v, 3 ph and we may check this lot twice a year. The other lot is wired on 480 volt, 3 phase, and we go to that lot at least once 3very 90 days. both lots are wired the same with a ground from the panel to each pole. This lot has had fuses added to protect each fixture from shorts from down the line. The fuses has helped but we are getting way to many ballst and lamps with short life. The incoming voltage is within 5 to 7%. The lamp lost is varied across the lot, not necessarily blowing the same fixtures. This lot is maybe five years old.
Can anyone try and give me some ideas as to how to slow down the lamp and ballast lost??
