Had an argument with a local power company employee about wiring for some parking lot lights at a church, he is want to run a duplex underground cable to the lights (2 conductor) lights are 120 volt, I say it has to be a Tri-plex (3 conductor) because the circuits are being feed from with in the building, so the nut and ground must be separate, he says they (the power co.) always runs a duplex cable, but I say that the wiring he does don't have to meet NEC because it is power co owned. you opinion and any code references.
