Hendrix
- New England
Is there a code section that addresses ground rods at each light ?
Thanks, the exception is the keyYes, check out 250.32(A) and the accompanying exception.
Chris
Is the pole a structure ?
Gotta be the single lamest excuse for a definition in the entire set! "That which is built or constructed." I built a kite in my youth. I once constructed an argument in favor of legalizing tap water. Sheesh! :roll:Check out the definition of structure in Article 100.
It is my understanding that the definition closely matches the building codes definition of structure.
Ergo, this forum is a structure.
So is my kids Teddy bear but it is unlikely that any NEC section applies to either.
Are you saying that your kids Teddy bear is not grounded? Oh the humanity.
Chris
But it's AFCI and GCFI protected, as well as on a TVSS.
