rhendric5651
New member
Along with being a teacher I have some rentals. Right now I have a duplex that is set up seperately. Two meters. The downstairs apartment is working fine. The upstairs apartment about every 24-48 hours will have a partial power outage. Appoximately 7-10 minutes later everything turns back on and is fine. The fuse panel has been looked at by an electrician and he said everything is fine in there. The power company said that the meter socket outside has some corrosion on the terminals. What could be causing this power outage. The electrician said he would start by putting in a new meter socket. I need some help with this problem.
Thanks.
Thanks.
