dugaselectric@roadrunner.
I have installed a 200 amp nema 3 MB -8 space service panel over the years. The panel has lugs at the bottom of the buss. This was used near the road next to the meter.The lugs allowed us to feed 4/0 cable through underground to a panel in the house
I had to feed a garage with a 200 amp service because I had no room to hit the house overhead because of a pool. I wanted to use the same panel and feed-thru underground to the house panel useing 4/0-200 amp cable. The inspector said I could not use the 200 amp as a disconnect. He said you can't sub-feed useing the same size wire to the panel in the house.
What am I missing in the code? What application could you use that style panel with feed thru lugs.
