PB Size
Alwayslearningelec
NJ
Estimator
Hello I have (16) 4" conduit coming into the bottom of this pullbox then existing the side. THis would be an angle pull? So it would be 6x largest conduit not 8?
What's size box you come up with given the additional conduits? Need space between each conduits for hubs(pvc coated conduit)
Thinking 50"x30" would work?
Edit , oh you need to add the sum of the other conduits...darn.
It would be 6x + the sum of other conduits in the same row. The 6x between conduit entries might be more significant. Is this a pull box ??
