I suppose you would also like a "free estimate" as well. :grin:emahler said:anyone know of an alternative to Adobe? mostly needed for editing cut sheets...a free program would be optimal...
aline said:I suppose you would also like a "free estimate" as well. :grin:
emahler said:yep...and i want you to come look at my computer and tel me what you think....
I find that many PDF documents that I'd like to edit come "locked". I have full Adobe 8.1, and you can't even unlock them with that unless you have the original password from the creator of the document. It's to prevent people from modifying contracts and such that are submitted electronically in PDF form.emahler said:anyone know of an alternative to Adobe? mostly needed for editing cut sheets...a free program would be optimal...
mdshunk said:I find that many PDF documents that I'd like to edit come "locked". I have full Adobe 8.1, and you can't even unlock them with that unless you have the original password from the creator of the document. It's to prevent people from modifying contracts and such that are submitted electronically in PDF form.
We use both PrimoPDF and Acrobat Pro. If you just want to make PDFs from Word or whatever, PrimoPDF is fine (and free)emahler said:anyone know of an alternative to Adobe? mostly needed for editing cut sheets...a free program would be optimal...
Rampage_Rick said:We use both PrimoPDF and Acrobat Pro. If you just want to make PDFs from Word or whatever, PrimoPDF is fine (and free)
It's only when you want to start doing fancy things like hyperlinks and clickable forms that you need the real thing.
As an aside, PDF isn't really a good format to be edited, in comparison to a word processor. Generally speaking, you should be making all your changes in the original document (i.e. Microsoft Word .doc) and generating a new PDF file after each change.
Adobe 8.0 Professional $169.49emahler said:i've been using Primo for awhile now...but it's just what you said...
i need an editor so that when we do cut sheets or when drawings are sent to me in a PDF form, we can edit them...
Adobe is just an overpriced, bloated product for what i need..
FWIW, I hear OpenOffice 3.0 will have PDF import and export capabiity. It is currently in public beta stage of production...emahler said:i've been using Primo for awhile now...but it's just what you said...
emahler said:i don't want to type in the info and have to print it out. i want to just type in the info and save it.
DanZ said:I use PDF reDirect, it acts like a printer, letting you edit PDFs in Adobe Reader (which is free) and print a new one in PDF reDirect.
It also has a couple of other nice features, like letting you rotate, or set color or black and white. The pro version (not free) lets you edit and apply digital stamps to what you print.
All that, and there's no ads like PDF995's free version!
emahler said:will it simply let me fill in a form and save it for emailing? or do i physically need to print it out?
