Grouch
- New York, NY
I posted a question months ago regarding Relocatable Power Taps (power strips) and extension cords. So in that discussion I learned that you can use RPT's at a desk, as long as the RPT is not permanently secured to the desk AND the RPT plugs right into a wall receptacle without the use of an extension cord.
That being said, I'm coming across an issue on a project (kind of similar question). We have a rack mounted UPS in an MDF room. The IDF room is located on the floor directly above. The client wants to install PDU's in the IDF room, but the power supply cord is not long enough to go down to the UPS on the floor below and connect to the UPS output. The electrical contractor is proposing to install a quad receptacle in the IDF room, and connect it to the UPS output on the floor below in the MDF room using a custom-made plug (I'm assuming it's some kind of custom-made plug). Now that we have a quad receptacle in the IDF room, the PDU's in the IDF room (on the floor above) can now connect to that quad receptacle. My question is... is this legal? I'm assuming not... for starters, the custom-made plug has no UL listing, and this installation would be similar to an RPT connected to the UPS via an extension cord. Any thoughts?
