jcbabb
- Norman, OK, USA
I'm getting confused trying to read some values from the attached let through current chart.
I am getting the available fault current from the utility, but i need to gather the following values from the chart:
1. Apparent let-through
2. RMS current
3. Peak let-through current
These values are being requested by the AHJ.
I've seen and done several of these types of exercises using let through charts from fuses. My confusion stems from the fact that this breaker let-through chart looks different from the fuse let-through charts that I've seen before. For example, on a fuse let-through chart, the smaller diagonal intersects are labeled with different values of ampere ratings. This breaker chart has them listed by voltage. My guess is that the "peak let-through current" is gleaned from where the "Maximum available let-through energy at 1/2 cycle without breaker" line intersects the available fault current. After that, I would think that the "Apparent let-through" value would come from the "up-over-down method" using the proper voltage line, and the "RMS" value would simple be the same as the available fault current.
Am I completely off base in my understanding of this chart?
2. RMS current
