Wirenut 1166
I have a customer that is replacing his electric gate operator. He is feeding it from a disconnect on the building. They ran triplex overhead from the existing building (Across the parking lot)to a utility pole. On the pole they set a sub-panel and drove a ground rod. From that point they ran 220-volts with a neutral and a ground. The new gate motor needs 220-volt with a neutral and a ground. My question is am I reguired to replace the triplex with quad plex and ground the system back to the service. As always I appreciate all you advise.
