Do either of you know the reasoning behind 210.52(C)(4), the range or sink in the middle of the peninsula that breaks it into 2 countertops if the countertop behind the sink or range is less than 12 ", but apparently if the countertop behind the sink is more than 12" it is still one countertop. I have 8 foot peninsulas. One has the sink in the middle and about 4" of countertop behind the sink, so that one needs an outlet at the end of the peninsula correct.? The other style they are calling a "galley kitchen". It also has the sink in the middle but it has 17" of countertop behind it. So you have 8' from the connecting wall, over 2' after the sink, but you don't need an outlet at the end of this peninsula because you have one at the connecting wall. (correct?) I believe that is the interpretation but I don't know what difference the width of the countertop makes. Again 2017 code, and as noted it looks like 2020 you would need that receptacle.
