encoreman
- Austin, TX
I need to make a run through a steel wall. It is a 1/2 inch think steel plate. Someone else is going to weld a 2 x-strong pipe through the wall about 8 inches long. I'm wanting to attach conduit to each end of the steel pipe and run conductors through the steel pipe. The other option would be to run conduit through the steel pipe, but then I would have to find a way to provide a seal between the conduit and the steel pipe.
Question 1:
Can I run conductors through the steel pipe?
Question 2:
If I have to run conduit through the steel pipe how should I seal it (the general contractor does not want to use foam)?
Thanks for your help!
Jack
Question 1:
Question 2:
Jack
