per cent fill on conduit
srmoran
I have 3-1000kcmil, 25 kv and 1-1000kcmil, 600v cable in 155mm conduit. My per cent fill is 43% which is above the 40 % limit. Is there any exception to this?
Re: per cent fill on conduit
I cannot think of an exception unless the conduit is a nipple not exceeding 24" length.
What is the function of the 1000KCMIL 600V. insulated conductor?
Does it really need to be that large?
Originally posted by srmoran:My per cent fill is 43% . . . .
How did you arrive at that value? If you found it by dividing the actual area of each conductor by the area inside the conduit, then you are stuck with a problem: find smaller conductors or a larger conduit. But I am guessing that neither option is available to you, or at least neither is attractive.
[ December 12, 2005, 11:22 AM: Message edited by: charlie b ]
What about looking into compact conductors. I've been told that they now come in copper as well as aluminum. You might just get under the 40% you're looking for.
Is 600 v cable allowed in a conduit with 25KV??? I thought everything had to be rated for the highest voltage present??
Steve
Good catch, Steve. This would be a violation of 300.3(C)(2).
That's one ATTABOY :) for Steve and one OOPS :( for me.
300.3(C) deals with Conductors of different systems.
I do not think the 1000 kcm is part of a different system. Its the neutral or grounded conductor of the 25 kv system. I believe it can be bare.
If it's a ground, and can be bare, that decreases the overall diameter...maybe enough to meet the 40% rule.
john
250.184(A)(1) requires the neutral (grounded) conductor of this system to have insulation rated at 600 volts.
Don
I get it now. I didn't know the neutral was allowed to have a lower voltage rated insulation.
I was kind of puzzled why a 600V conductor was in a conduit with high voltage!
srmoran: Can you tell us what the 1000 MCM 600V conductor is? Also, can you answer my previous question?
