I have a situation on a hotel project where normal and emergency lighting circuits are switched at the same location with different switches. I would like these switches to occupy the same back box so that a single cover plate can be used. Per NEC 700.9(B) this wiring must be separated, but per NEC 314.28(D) they are considered separated with a permanent barrier installed.
Can anyone point me towards a 2-gang or 3-gang product that has such a permanent barrier?
Or is this something that is typically field installed? If so, is it welded to make it permanent?
Thanks.
Thanks.
