mek421
- Upstate NY, USA
There have been a few threads about motors tripping AFCI devices recently. My reading of code seems to be that simple over current protection is sufficient for an attic. If a permanent stairway leads only to an attic, is it acceptable for a receptacle to be installed at the bottom of the stairs for use as a vacuum cleaner receptacle? (The attic has a ceiling height less than 6' at the peak of the roof.)
I'm in NY, this is the relevant portion of residential code:
E3802.11 Arc-fault circuit-interrupter protection. All branch circuits that supply 120-volt, single-phase, 15- and 20-ampere outlets installed in family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreations rooms, closets, hallways and similar rooms or areas shall be protected by a combination type arc-fault circuit interrupter installed to provide protection of the branch circuit.
