Davebones
- North Of Tampa Fl
We had a new service ( 2000 amp ) and some bus duct ( 480v ) added in part of our plant . This was done with a outside electrical contractor with a electrical permit . This area will get filled up slowly with equipment over a period of time . The electrical inspector wants permits pulled and load calculations done on any equipment tied in or moved around . This is stuff we normally add a bus switch and pipe over to the machine ourselves and tie-in . We move equipment around often when management decides there's a better way to lay it out ( KAIZEN ) . It can be equipment from 15 amp to 200 amp feeds . I don't see how this can work with the way we constantly move our machines around and pull permits at the same time . ( This is around 200,000 sf , people that work in a manufacturing plant will understand the constant moving ) . We have a Master Electrician and Journeyman that do the work . My boss will have to deal with the county on this , just looking for some thoughts about this .
