Any thoughts?
Today at a customer's home I was checking a 120v duplex for voltage.In doing so I noticed the hydronic baseboard carried the 120 volts from the outlet to ground,when I had my testers between the two points. The odd thing is that this baseboard is fed with pex tubing. My first thought was the heating system is fully charged,and the water in the tube is the conductor.I have the same system at home (so I tested ).one zone in my house is 47 volts and another zone is 70 volts. When I turn my circ on Both zones rise 20 or so volts.
So my question is my system the norm? Or perhaps the customer's loop is fully charged providing low resistance path (mine air bound).Or lastly maybe a screw through the baseboard housing and into a romex ? Has anyone ever seen this or am I the only nut!
Thanks
Thanks
