brycenesbitt
- United States
My local utility's clearance rules don't always work very easily on older building:
Has anyone had luck with getting PGE to extend the gas regulator's "vent" in durable pipe, thus changing
the points that must be 36" away?
The gas regulator has a pressure vent so can leak small amounts of gas in normal operation: this
is often why you might smell gas in an enclosed meter closet even if there's no "leak". Presumably this
gas leakage is the reason for the 36" rule, is just not how 100% of the original home stock in my area was built.
