This is gonna be somewhat of a 12volt question. I have a onboard battery charger on my boat, three prong on charger and three prong plugging into it. I'm getting 36 volts on the A/C side of my meter if I touch my metal bld to any metal part of the boat when the charger is plugged in. Unplug the charger and the voltage goes away. The way I found it was my daughter touched the metal rail with her forearm and felt a light tingle. I put a 12 volt light tester on the metal and it barely and I mean just barely glows. I would think if it was a true 36 volts the bulb would be very bright. Also this is the second charger I thought at first maybe the charger was bad. Any ideas? Thanks
