phase converter
Toros
Tujunga, CA
Hi
i have an old building that is served with 120v, or 2-wire system
i am looking for a phase-voltage converter for the new 240v AC unit
any suggestion??
Thank you
Toros
Tujunga, CA
What you need is a new 120/240 volt service. Minimum size would be 100 amps to a residence.
You could use a transformer to step up the voltage to 240v, but by the time you got done messing with that, you will have paid for the new service.
need a transformer for the new ac unit only
5 kw 120v step up to 240v 1 ph
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
You're OP said "phase converter" which implies 3Ø. Now you say "transformer". If all you need is single phase 240V then a transformer might work. Having said that, I don't know why your customer wouldn't want a 120v/240V service. I didn't realize there were any 120V only services still in operation.
Toros
Tujunga, CA
Because the building is in LA and it takes very long to get a new service
besides
new rules applies for new service location
it is difficult and costly to comply with....
Besoeker3
UK
Retired Electrical Engineer
I’ve never seen a 120V only service larger than 60A, I think they are going to be overloading their service drop.
Possibly....... 60A @ 120V is obviously 7.2kVA. Might be enough for his 5kW load.
curt swartz
Electrical Contractor - San Jose, CA
San Jose, CA
I'm sure they exist but I have never seen a 120 volt utility service over 30 amps in California. Usually the next step up was 60 amps 120/240.
