G
Guest
Guest
I'm building a rotary phase convertor for a home workshop. My idler motor is 15HP. I'm using a bank of oil-filled motor run capacitors as the motor start caps - about 1500 mfd. The start caps are pulled into/dropped out of the start circuit by a contactor controlled by a potential relay. I want to install a resistor across the cap bank to bleed off any residual power left in the caps when the caps are dropped out of the start circuit.
What's the formula for calculating the resistance and watts rating for this application? I know that I don't want a low resistance because that would bleed off too much power when the motor is starting. Would a 10K-ohm, 50 watt resistor work?
Thanks, Rob
Thanks, Rob
