One of our hvac techs was sent to a facility to check a Carrier RTU that was not working. This was installed about a year ago with no problems until a storm came through and the unit stopped working. He found the phase loss monitor was not working, He had 240 volts between A-B, B-C, A-C, all were within 1 volt. No neutral, measured 240 volts to ground on two legs but 0 volts to ground on third. Facility electrician confirmed readings and said it was a corner grounded delta system. A replacement PLM was installed but it would not close either. When monitor was bypassed the unit ran fine with all readings normal.
I do not know the make or model number of the PLM but could someone confirm that it should work with this Delta system. Do they typically monitor to ground?
Thanks, Glenn
Thanks, Glenn
