Do all delta / wye xfmrs. Conatin a phase shift? What is the purpose of a 30degree shift? As opposed to a delta/delta with a zero degree phase shift, And what is the best way to determine if the utility is a wye or delta conection?
It might be worth adding that there is no phase shift between the actual windings on each coil. The phase shift is when you go line to line. The Y side line to line is made up adding two line to neutral voltages with a 120deg angle between them.Yes, all delta-wye transformers have a 30 degree phase shift. It is a function of the phase angle differences between how the primary and secondary coils are hooked together.
Transformers are not particularly good for harmonic attenuation, particularly lower order harmonics.There is no real purpose of the phase shift, however, delta-wye transformers are sometimes used to either trap triplen harmonics in the delta winding, or they are used along with transformers with no phase shift to cancel harmonic currents from six pulse drives.
Not sure I agree with this statement. I do agree that voltages and currents on "complementary" windings are in phase. The shift occurs from the fact that primary windings are connected line-to-line whereas secondary windings are connected line-to-neutral. Note in the following diagram how primary line-to-line "vectors" are the same as the secondary line-to-neutral vectors. Each system's phasing is referenced Line A/a to system neutral, which for delta configured windings is a virtual point at the "center" (can't think of the correct geometric term at present) of the triangle, so indicated with the dashed line.The phase shift is when you go line to line. The Y side line to line is made up adding two line to neutral voltages with a 120deg angle between them.
In the diagram you show, the primary is leading the secondary by 30 degrees.Not sure I agree with this statement. I do agree that voltages and currents on "complementary" windings are in phase. The shift occurs from the fact that primary windings are connected line-to-line whereas secondary windings are connected line-to-neutral. Note in the following diagram how primary line-to-line "vectors" are the same as the secondary line-to-neutral vectors. Each system's phasing is referenced Line A/a to system neutral, which for delta configured windings is a virtual point at the "center" (can't think of the correct geometric term at present) of the triangle, so indicated with the dashed line.
...however when looking at the voltage drop it gave the voltage drop as a negative integer? How can the voltage drop be negative? When I asked about this I was informed it?s what the software says but how is my question?
That's what I said.Not sure I agree with this statement. I do agree that voltages and currents on "complementary" windings are in phase. The shift occurs from the fact that primary windings are connected line-to-line whereas secondary windings are connected line-to-neutral.
That's what I said.
The shift is between primary line to line and secondary line to line.
Well just a simple construction electrician with a question, phase shift between windings pri to sec only happens on a delta wye or a wye delta transfer why ? now its 30 degrees A phase delta to A phase wye on transfer if so how or why ? i just thought its was due to the induction of the coils or windings ac reactance to time in cycles between each pri to sec winding or the way transfer happens to time can you clear this up for me in simple terms ? take care
... virtual ...
[/IMG]
The only time it matters is when sources are being paralleled. If the supply is only a single transformer it is immaterial.Every time I read about the "phase shift" between primary and secondary (which is not an actual delay, but just an electrical difference), I wonder why it matters.
It's not like we're going to connect anything between, say, a 480/277v distribution system and a 208/120v panel supply. Why does the difference matter to us?
I have an application where I need the 30 degree phase shift.
Is the isolation transformer just a delta primary, wye secondary transformer?
