Re: Phase to neutral wiring
OK. Now that I think I understand the question, I have to admit that (1) It's a good question, and (2) I don't know the answer. But let me restate the question, in what I hope will be a clearer way, and see if anyone else can cite the code article (if any) that would be violated.
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Start with the main panel in a house. Let it be the only panel in the house. Let it be single phase, 120/240 volt.</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Connect black #12 AWG THHN wires to the 20 amp breakers in slots 1, 2, 3, and 5.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Connect one white #12 AWG THHN to the neutral bar, and one bare #12 to the ground bar.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Run all six of these wires out the panel, through a single 3/4 inch conduit.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Connect each of the four black wires to a separate load. Bring the same white wire to each of the loads.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Let's say that all four loads run at the same time, all are continuous, and each draws 16 amps.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Do you have a code violation, and if so, please provide the article.</font>
<font size="2" face="Verdana, Helvetica, sans-serif">Please note that with the derating for 4 current-carrying conductors in one conduit, the black wires are still good for 24 amps. So no black wire is overloaded.
However, the white wire will see 32 amps of continuous current, and that exceeds its rating. Obviously no good. But I'm drawing a blank: What article says you can't do that?
Now let me complicate matters a bit. Let's make the white wire a #8. Use pigtails at each load, to allow connection of the white wire. Now the white wire will not be loaded beyond its ampacity. Is there a code violation, and if so, please provide the article.
Stevej: Did I paraphrase your question correctly?
