hartley590
New member
is it legal to phase black wire with colored phase tape inside elec. power panel?
This is a good idea but it's not required by the NEC. Two wire cables containing only black and white conductors can occupy the same box even if they're from different circuits and would not require any further identification.However, if you have two 2-wire circuits in the same box downstream of a panel then the hot lead for the second circuit should be a different color so that it is obvious that 2 circuit breakers need to be turned off.
Originally posted by hurk27:
Must have worked in hotels all his life?
That`s the one thanks i was tossing and turning trying to rememberOriginally posted by Nick:
The tape measure way goes like this. Take the number 37 for instance. Run you tape measure out to 37 inches. There will be a number 1 above 37 (3'-1") You already know 1 is A phase and as it so happens so is 37.
