scandle
- clarksville, tn
[h=2]Phases and rotor repair[/h]
Generator is Devilbiss GBV7000 with a B+S 14hp motor.
Problem: The insulator on the rotor broke and the winding came in contact and shorted to rotor shaft. Generator only puts out 120Vac. The shorted winding read 0 ohms to shaft. I unwound the wire repaired insulation and then rewound the rotor winding coil. With the rear cover removed I read 120vac between the green and red wire and also beteween the black and orange wire I have 120vac. So far so good two seperate 120VAC sources. The 2 phases only measure 18-20vac to each other. The 2 diodes on the rotor are good.
Question Is it possible that I wrapped the rotor winding in the wrong direction CW vs CCW?
I did try reversing the diode and with the diode reversed the stator windings read from green to red 10vac and orange to black 10vac. I have since soldered diode back in with original polarity and now am back to 120vac on both stator windings.
It appears as if the two legs of 120vac are in phase with each other thus when one is high the other is also rather then at the low and thus the low reading from phase to phase. Would winding it in opposite direction cause the phase to invert and make the peak to peak voltage read 240? Im really at a loss and just guessing at this point.
