RubyMantis28312
- Wallingford, CT USA
I have a 3 wire coming into a junction box - black, red and white. I have 120v from black to ground or neutral, 120v from red to ground or neutral, and 208v from black to red. The neutral is capped. From the junction box, a 2-wire goes to a dead-end key switch that ties into the black and red. The key switch is a close-to-make style. So I have 208 going directly to the key switch. When I close the switch, it turns on a motor but I'must unable to see how it gets there. When the switch is closed, I can no longer read 208v from phase to phase but I do have 120v from each phase to ground. How is this possible? I tested for continuity and the switch is definitely causing the wires to make contact. The switch appears to be feeding in and out on the same wires.
