iwirehouses
There is a 4 conductor phone jack in an office. The phone connected to that jack has 5 lines. How is this possible?
iwirehouses said:There is a 4 conductor phone jack in an office. The phone connected to that jack has 5 lines. How is this possible?
With digital phone systems, you could have a billion "lines" appear on the face of the phone, and have it only need one pair. That's all done through the programming of the switch in the phone room.iwirehouses said:There is a 4 conductor phone jack in an office. The phone connected to that jack has 5 lines. How is this possible?
You need to know a bit about the system, but yes, that's how you do it with a "system" type phone. Then, you need to set up the TN's and DN's for the phone in the switch programming, and get all the features that you want on that phone programmed. It's reasonably safe to say that you might be in over your head on this one, other than running the cable and installing the jack.iwirehouses said:Would I ned to run a dedicated line from the switch?
Depending on the manufacture, more than likely it has to be ran dedicated to a switch port and programmed. Basically all you can do is pull the wire, then call the vendor to do the rest. They are not going to instruct you how to do it.iwirehouses said:I went to the jack, put in a splitter, and ran a second line to a second phone. Only line 1 would work, and actually, when I hit line 2, it turned off all the phones in the room. Would this be accomplished via programming the switch, the phone, or some other means? Would I ned to run a dedicated line from the switch?
mdshunk said:There's a lot of information on the net on how to program many systems. Many of the complicated systems, like Nortel's Meridian, have a whole "ecyclopedia set" that goes with them. It's usually in the phone room in businesses that have bigger systems like that.
You too can be a M-A-C daddy!
Very, very true. Luckily, I have a clue, and a few to spare. My response was more tongue-in-cheek than anything. I'd certainly hope a guy, when sitting face to face with a Meridian terminal for the first time would think better of it.mkoloj said:IMHO If you walk in not having a clue and try to do some programming on a NT Meridian system you will be in for a rude awakening trying to go thru those books to find what you are looking to do.
TOOL_5150 said:I used to program M1 systems. Some of the 'professional assistants' had 28 lines to their phone, with rollover non ringing lines to other assistants - all on 1 pair of cat3. I still have the Meridian manuals, over 100 pounds of them. Some people wanted to do some of the strangest things with their phones.
Im glad I am an electrician now. The PBX techs are getting to be a thing of the past thanks to viop.
~Matt
lakevillejake said:most digital phones cannot be tapped this is a security feature. line will go dead if you try to tap
