Short.Circuit
Just curious what kind of gear you guys wear. I've had these since apprentice days in the early 90s... work really well. I add tools depending on what I'm doing, but this is the basics...
Right side I carry a twirly screwdriver for plate screws, good phillips, good long regular screwdriver, big screwdriver for chiseling things, curved dykes, strippers, twirly wire nut driver, tape measure, razor knife, pencil, pen, felt black marker, 2 nuts drivers (popular sizes), hot stick, fine small regular screw driver (for getting wire out of stabbed devices), holster (carry hammer there or screw gun), has pocket for nut drivers I chuck in my drill.
Left side is wire nut pouch (yellows & tans in big section, red nuts in smaller one) & general small pouch (usually carry stapes there & crimp sleeves). Do mostly resi... plastic container carries staples, sheet rock screws, long sheet rock screws & plastic plumber's pipe for shimming devices, safety pin with shims from receptacle/switch ears, 8/32s, 6/32s, crimp sleeves, ground screws & tek screws...screwtips for phillips & square/canadian head drives & drill bit
Suspends help a lot, padded as well...
edit to remove silly shirt & explode bags
edit to add the rest of the crap ;o)
