Hello everyone, I have seen an installation where 4 wall mounted inverters were installed in such they stack, two of them mounted above 7' (at bottom of inverter), is this a code violation?
Also, the 4 invertors feeds into a dedicated panel via 4 AC disconnect switches into 4 circuit breakers. This panels feeds into an upstream breaker in subpanel. This subpanel is fed from the main electrical switchboard. Let?s say someone wants to work on the main switchboard service and turned the main breaker off. Is there any chance the main switchboard will be hot due to the subpanel being fed from the photovoltaic panel? does the breaker in the switchboard will prevent the back feed from downstream power source?
Thanks,
Thanks,
