I don't rememeber if it is the NEC code or NABCEP that now specifies the following: If your solar panels would be grounded to a point more than 6' away from house ground, they must have their own grounding electrodes.
This is completely wrong. Think of this: You have a microphone at the end of a 50' length of coax. One terminal of the microphone connects to the inner and the other terminal to the sheath. Would it be better if instead we disconnected the latter from the sheath and connected it with a piece of #14 to the ground terminal of the nearest receptacle? Try it! The hum will blow your speaker cone!
The problem is, having wires from the solar panels to equipment grounded at the house ground and another wire from the solar panel frame to a separate grounding system creates a huge loop antenna. This will increase the radiation of inverter hash, as well as inducing an enormous transient into the current carrying wires from the solar panel to the rest of the equipment when there are neighboring lightning strikes.
If lightning hits the panel frame, your'e going to get creamed with ths method, because a 25 ohm solar panel ground will do nothing to hold down the voltage. You will have a million volts on the panel frame relative to the solar cells, it will arc across from frame to cells, and thence to the inverter. If however you ground the frame via the conduit that carries the cell output to the inverter, they will all go up to a million volts together, with little potential difference to cause damage.
Coax is King!
The manuacturer's recommendations for my Xantrex inverter installation recommend exactly the opposite of this new code. Everything should go back to the same ground, and ground wires should run in the same conduit as hot and neutral wires. The frame of solar panels should be grounded via the conduit and/or this ground wire.
The code needs to be changed pronto.
Coax is King!
