1-29 Log #261 NEC-P01 Final Action: Reject
(100. Enclosure)
_____________________________________________________________
Submitter: David Shapiro, Safety First Electrical Contracting, Consulting, and
Safety Education
Recommendation: Revise as follows:
Enclosure. The case of housing of apparatus, or the fence or walls surrounding an installation to prevent personnel from accidentally contacting energized parts, or to protect the equipment from physical damage.
Substantiation: The word is superfluous. Submitting proposals removing the adjective may strike people as useful as hunting gnats with a cannon. However, doing so seems worthwhile for two reasons. First, if we eliminate every instance, as I am attempting to do, we actually cut the NEC down by up to oh, half a page. Keeping it from growing too much fatter every cycle is a goal many of us can agree on.
Second, the use of ?physical? is not only poor writing?look at William Zinsser?s classic, On Writing Well? but silly, and reflects a bit poorly on the Code process. When the references were changed to ?physical damage,? in 1959, from ?mechanical injury? (with no substantiation recorded), an excellent opportunity was overlooked to eliminate the possibility of someone raising an eyebrow and saying fatuously, ?Is anyone claiming electrical equipment needs protection from non-physical injury?? (Substitute the snide adjective of your choice.) Let?s take care of that for good: for our purposes, ?damage? means ?physical damage.?
Panel Meeting Action: Reject
Panel Statement: ?Physical damage? is a common term used in industry. Generally, it is damage caused to property from external events, such as accidents, vandalism, destruction, and other potential hazards. CMP-1 notes to the submitter that an enclosure does not protect equipment from internal events, such as caused by short-circuit and ground-fault conditions or computer and data errors. In addition, this proposal is in violation of 3.2.5.5 of the NEC Style Manual, as the term ?physical damage? is a special term identified in that section.
Number Eligible to Vote: 12
Ballot Results: Affirmative: 12
