joanie
I have a facility where fire alarm panels were installed directly above each other, amid other electrical and mechanical equipment. Portable ladders must be used to access the top panel and work clearance is essentially zero, although the panel door will open at least the 90 degrees required. I know that all electrical equipment must be readily accessible, but Article 760 doesn't mention that this equipment must be readily accessible. Article 760.51 mentions that the "conductors and equipment on the supply side of the power source shall be installed in accorance with the appropriate requirements.....," but I cannot find enough specific verbiage to have the contractor relocate the fire alarm panel. It is approximately 7 feet off the floor. If someone can help me with specifics, I would appreciate it.
