I'd like to ask a hypothetical question that seems not to have a simple answer.
A circuit is protected at a some amperage and feeds multiple fixed & variable loads. The loads are wired and/or rated by their various manufacturers without consideration of the circuit OC protection. Won't the "weakest link" render all but the simplest circuits a hazard?
For example, if a 15A breaker is wired with #14 copper and connected to standard switches & receptacles, it is considered safe. Adding any load rated/wired below 15A creates a weak link, rendering the OC protection ineffective. A small load wired with #16 copper, for instance, can overload without ever tripping the primary OC protection.
I've heard dozens of opinions about this over the years, but no definitive answer. Thanks for your comments.
