Jim W in Tampa
- Tampa Florida
There is no way in h-- that i would even touch that mess.You just put your name on this garbage.If a permit was required ,please save a life and turn it in.
I agree! If you are there to troubleshoot, then make sure you list that in your invoice. I would also list any noticeable violation on the same invoice.Jim W in Tampa said:There is no way in h-- that i would even touch that mess.You just put your name on this garbage.If a permit was required ,please save a life and turn it in.
LarryFine said:To start with, shouldn't that panel have a main breaker?
Agreed. (And welcome.)Skyline Electric said:That's so bad it almost looks intentional. Like "here's what not to do".
LarryFine said:Can anyone spot anything compliant? :-?
I've seen more orderly worms!iam14sure said:Talk about a can of worms....
Permit? Inspection?VinceS said:How did the inspection pass?
Why ? Its a sub panelLarryFine said:To start with, shouldn't that panel have a main breaker?
iam14sure said:Looks like a Jandy PS-8 panel. The panel is listed and actually accepts all kinds of breakers such as Homeline, Seimans, GE, Cutler Hammer BR etc. Has listing right on door. The relays are controlled by a wireless PDA. By the way, UF is not approved for the feed or for the light. Talk about a can of worms....
brantmacga said:This is from a new pool contractor in town; this is their 5th job. They've been doing all their own electrical so far, and they called me a week or two ago to see if I could start doing their work. Since then, I've been called to troubleshoot two of their installs. Here's one from today (the first looked just as bad).
Enjoy:
Ughh.
The GFCI was tripping with one of the shell lights connected. There was a short somewhere in the UF that was feeding it, and the bulb was blown.
Jim W in Tampa said:Why ? Its a sub panel
firelient said:Shouldn't there be a Gfci on more than just the light.... The pump maybe and anything else close to the pool?? Need to post at local dist. on how not to wire a pool
