brycenesbitt
- United States
Ok, I'm looking at several 20A circuits that once had a breaker in a main panel.
The breaker was subsequently moved to a nearby (other side of wall) four wire subpanel.
Only the hot and neutral were extended over. Of course, nothing was labeled. No GFCI or AFCI.
The question is the ground wire on the original circuit.
Should that be extended to the subpanel also?
The current setup is confusing, but is it unsafe or incorrect? Any ground fault will
get to the main ground either way.
