electricaldoc
The IBEW pushes that so called pig tails (wire nuts splicing wires together with one left out for use) are required on every wire at every receptacle. Our NEC instructor told us it is code, but I can not find it in code. I have only found that the grounding conductors must meet this requirement, so no outlets down stream lose their grounding conductor. He claims this is required for all conductors for the same reason, but he could not find it in code. We pointed out a picture in NEC hand book of a receptacle wired with hot coming in on one side and out the other and same with grounded conductor. We said if this picture is in hand book then it must be legal, which means we are correct only grounding conductor required to be pig tailed.
Does anyone know if this is true and where in code?
Any help appreciated.
