Flex
- poestenkill ny
Is there a code that requires you to pigtail neutrals for a receptacle ckt? I found a code for mwbc but not for a single ckt.
I have noticed that some residential guys always pigtail neutrals.
I assume it was easier to tell them "always pigtail white/blanco" than to actually teach them the reason behind pigtailing the MWBC neutrals at the split point.
I remember seeing the work of a major residential contractor in CA that pigtailed all their receptacle connections. Pigtailing? In tract homes? Huh? :-?
Pig tailing is just a good, very reliable practice. It usualy makes getting the recetacle in the box lots easier too.
Takes about twice as long and you use wire that you could be scrapping for the Haggen Daz fund!
That'll work as long as you feed it with a suicide cord.here's how i do quads.... for residential even, peter...
If your guys can't figure out when to pigtail and when not to you need to do some training. This is supposed to be a professional trade(some of us) and a "electrician" should be able to make basic judgement calls like this.
I like pigtailing. My opinion is it is a better install. Just my opinion though.
In residential it adds uneeded costs to the install.
