khillelectric1
New member
where in the code dose it say you must pigtail if there is more than two conductors intering a outlet box for a receptacle.
only required on MWBC neutrals
You can use both screws
So basically only 2 wires each side
I would not do it on commercial but is permited
Jim, what do you mean by "you can use both screws?
Doesn't that conflict with 300.13 (b)
300.13 is saying you must use pigtail on grounded (neutral)
others can use screws
