klineelectric
- FL
- electrical contractor
One county lets us wire barns that have exposed/open trusses (no ceiling} with uf wire and sleeve down from ceiling to weatherproof boxes (switch/outlets) with weatherproof covers in pvc. The next county over says ALL wiring must be in pipe and have dustproof enclosures. The barns are on residential property, not commercial. Some are typical pole barns and some are concrete block and truss. I understand that PVC or any pipe would be better, but most homeowners here only see the lowest bid price when picking their contractors. What section of code should I look under to find the code compliant way?
