I love having a big pipe wrench around. Bought a 48" last year. Needed to rebuild a big hydraulic cylinder. The rod nut was about 4.5" across the flats, torque spec of 3200 ft lbs LOL. Needed a 10 foot cheater pipe to get it off, and a both a truck and the tractor to hold the eye end. I kinda want to a bigger one now, just to have.....If you work industrial for any period of time. You will use a pipe wrench and maybe even a 36” lol
Yeah those are nice. A cheaper way to go is a flogging spanner/striking wrench. ITs a heavy duty short stubby wrench that you hit with a sledge hammer.If you are doing that kind of stuff you need a torque multiplier. We call it a 4 to one. And of course a 6' torque wrench and 1" drive sockets...
If you were cracking 3000lbs im suprised the wrench didnt crack...
Yeah the aluminum ones sure are niceOne industrial job I had required installation of rigid up to 2 1/2". I bought aluminum pipe wrenches for this. Easier to haul 3 different sized aluminum wrenches than a 3' steel one. For smaller pipe, the rounded jaw channellocks do the trick.
You want to take back your OP now?I just used one to get a close nipple out of a condulet. Had to use a 1"1/4 pipe as a cheater. Worked great.
Yes!You want to take back your OP now?![]()
