VirutalElectrician
- Mpls, MN
- Sparky - Trying to be retired
I was just reading the thread about the USB charger in the sofa fire....
I decorate a bit for the holidays, and I'm starting to look into using pixels for color changing animated displays. Pixels in case you don't know, are computer controlled 3 color LEDs operating on 5v or 12v. People typically have thousands if not 10's of thousands of these in a display. After all is said and done in buying wire, props, controllers, etc, you're looking at about a $1 per pixel to do a display.
So what does this have to do with electricity you ask? Well, these things are starting to cause some fires. Especially the 12v variety. All the pixels operate at 5v, so the 12v variety use a regulator or resistor to step down to 5v. So why use 12v then you ask? Because these have a fairly high current draw, so there's a fairly high voltage drop on runs that are fairly long with a large number of pixels. So 12v is used on longer runs (mega trees, house outlines, etc) to avoid voltage drop or havin to do mid-span power injection.
The power supplies used are UL listed, but the pixel strings themselves are of course not. There's been some discussion on whether or not an insurance company can deny a claim based on using non-UL listed pixel strings if they cause a fire.
Here's some pictures of the fires...The last image is of a house fire that the owner believes was started by his pixels. He hasn't posted a formal follow up since his fire 2 weeks ago.
