I have a 100 amp service panel mounted inside a shop building and will be hooking up two 1/2" copper coated grounding rods over six feet apart to ground it. The #4 solid copper ground wire is running from the box through 1 1/4" PVC conduit and exiting about two feet below-grade outside.
Q1: Is 1/2" grounding rod sufficient for this application?
Q2: Can I drive the first rod approximately 6" or less away from the outside of the building?
Q3: Can I run the #4 copper wire continuously from the grounding clamp on the first rod to the next rod?
Thanks for your help in advance,
Richard Linespike
Richard Linespike
