bernardmulherin1978
- augusta georgia
I was going to lay some outlets out today and was wondering what section in the code book says about placement of the outlets. OK you have two rooms and one wall that will have outlets that will point into each room off the same wall. What is the code on a outlet being in between the stud and one pointing into one room and the other pointing into the other room but inside the same chase in between the two studs. For some reason I am thinking it is against code to point one into one room and the other into the other room, in between the same two studs, is that not against code
Sent from my SM-S367VL using Tapatalk
