mbrooke
Batteries Included
- United States
- Technician
Is any one aware of, or sees  an advantage in placing PTs within breaker bays (between the circuit  breaker and disconnect) instead of on the outgoing line positions?
			For transmission substations, there are a variety of reasons for doing it either way. Its more common to put the line PT on the line side of the disconnect because it indicates the actual state of the line regardless of the position of the disconnect or breaker. For lines that have power line carrier, the PT is typically on the line side.
I think some utilities put the PTs before the disconnect for maintenance or replacement purposes. It allows you to PM or replace the PT without dropping the line out.
Thats the driver here, that and if the PT fails, the line can immediately be put back into service by isolating the breaker bay.
But, I want to ask, how important is it in general to know the line's condition?
Most substation operators and lineman will tell you that they prefer to have a local status of the line.....whether it be a panel indicator light or a panel meter. That lets them know that the line is heated up from the other end.
