Paulietools
I am working on a boiler valve train skid that will be located in a Class 1 Div 2 location. I am unsure of the placement of my seals. It appears that seals are required when making the transition from Haz to Non-Haz area however all of my wiring is going to a J-box located on my skid, I am not making any connections to the facility. All of my devices are rated for Class 1 Div 2 and the j-box does not contain any devices only terminal blocks. Where am I required to put seals? At all the devices and the j-box?
If I use ITC cable quick connect connections from all the devices I am pretty sure that I don't need seals at the devices but I would then have a central backbone of conduit where all the quick disconnect cables mate. I am assuming then I would only need one seal where the conduit enters the j-box.
