Hi all,
Ive got a 7.2V 1100ma battery i want to charge (used for RC's)
Original charger has burnt out
Ive got 2 DC power packs, both identical:
They can each output between 1.5V ~ 13V (adjustable through POT)
They can each supply upto 600ma
Question 1 is, if i wire these 2 chargers in parallel, and set both to 7.2V, will i be able to charge the 7.2V battery? (Is this even safe?)
Question 2 is, what is the difference of NiMh NiCad etc batteries? Will they charge using a regular power pack?
Question 3 is, how do you safely measure current in any given circuit/battery/power pack without electricuting yourself or blowing the fuse in the Multimeter?
Thanks in advance for any knowledge you can share,
Rocco
Rocco
