Joe.B
- Myrtletown Ca
- Building Inspector
.......... the back half of the clamp on the rod is backwards? Clamp too big for rod.
Also the back half of the clamp on the rod is backwards? Clamp too big for rod.
Interesting that nobody mentioned the absurdity of grounding a metal pipe coming out of the ground.![]()
some use stainless screws.It's questionable whether the clamp is listed for the rod. It's also questionable whether he should have used clamps with bronze screws that will last much longer in the outdoor environment.
If I had concerns or if this is a grounding electrode - I say jumper the sharkbite connector. That buried water pipe likely has less resistance to earth than that rod - presuming it was specifically driven for this purpose.It is my understanding that the buildings have a mix of steel and copper water pipes, it's an apartment complex with about 12 buildings, all built at different times. None of the buildings are new enough to have plastic piping. I asked about the sharkbite connector and they are not intended to maintain conductivity. This is why they installed this setup, I would have thought that a little jumper around the compression fitting would have been cheaper and easier, but I guess this achieves the same goal. The buildings are properly grounded and bonded elsewhere so I felt that I could "ignore" this. I thought it was pretty funny though...
