Some time back I hooked up a small Plasma cutter. The unit had a 20amp 120v molded cord on it. So while cutting thick material it will trip a 20 amp 120v circuit....It also had a switch on the back to switch it to 240v which obviously pulled half the current. So I made a adapter cord for it which had a female 20amp cord connector and a 20amp 240v male plug on the other end. I installed a 20amp 240v circuit to run the machine in the shop. Then they could remove the adapter cord and plug it into a 20amp 120v recept in the field for short duty cycle jobs...
So my question is how do you do this according to code? would my method be correct or not? I didnt like having 240v on a the 120v plugs but I didnt know what else to do....The adapter was the dangerous thing, if someone used it for something else....I labled it really well....DANGER bla bla
