ididion said:Are plastic switch plates okay to use on exposed boxes in residential open stud areas such as attics?
If you use the NECA NEIS specs as your guidance for 110.12 matters, then you might have an issue with the use of certain cover plates on exposed and surface mounted boxes.ididion said:Are plastic switch plates okay to use on exposed boxes in residential open stud areas such as attics?
Beats me. I use plastic (nylon) cover plates on exposed Carlon boxes in resi work. I do keep those boxes mounted flush with the front edge of the stud or rafter, however, such that the cover plates lays on the stud or rafter on at least one side. I do not, however, ever use a plastic cover plate on surface mounted work, like handy boxes. That's the ultimate in hackdom. Every time I see a furnace disconnect handy box on the side of a furnace with a plastic cover plate I want to cry. Matter of fact, I seldom use handy boxes for surface mounted work anymore. Mostly 4 squares with whatever RS cover.ItsHot said:Marc I am guilty!! What do you think is a good option. Handi-box?? With metal switch cover, the one sized for handi-boxes?
mdshunk said:Every time I see a furnace disconnect handy box on the side of a furnace with a plastic cover plate I want to cry. Matter of fact, I seldom use handy boxes for surface mounted work anymore. Mostly 4 squares with whatever RS cover.
